HouseBot now has an Android Software Remote!
An Android Software Remote allows real-time monitoring and control of your HouseBot system from any Android device. The Android app is constructed dynamically from the Theme Designer in the HouseBot server. Themes allow the user to use predefined user interface widgets, or users can use their own graphics to create very customized interfaces.
HouseBot is a Home Control solution that provides control and status of many types of home automation equipment. It is expandable to incorporate new devices and custom hardware.
HouseBot runs as a Windows application that can use a variety of automation protocols to provide a heterogeneous solution for home control. Software Remotes extend the control of the automation server by using customizable graphic interfaces that can run on remote (and mobile) devices.
HouseBot connects to other devices through "hardware interfaces" that connect to the PC's USB, serial, and ethernet ports. HouseBot's open platform allows new interfaces to be added through an SDK.
Tasks are created with a simple point-and-click task wizard to set up sophisticated events without any manual programming. Tasks allow monitoring and control over any Device setup in the HouseBot system.
Software Remotes run on Android, Windows, and Windows CE devices for real-time monitoring and control of your HouseBot system. Software Remote user interfaces are constructed by simple drag-and-drop editing to create interactive (2-way) control panels.
The complete HouseBot system is available in two different options (Trial and Full License). Both use the exact same installation files but are just licensed differently.
The current version is 3.56. Older 3.x versions can simply reinstall the newer (free download) version over the existing install and retain the prior licensing.
HouseBot support is managed through the online community forums. Many common questions and issues have been addressed by other users or by CeBotics in the past and are immediately available through the forums. The forums are monitored by CeBotics for support issues, but all users are encouraged to participate since the wide range of applications for HouseBot exceeds the experience of any one user. By searching the forums, many questions can be answered simply by reading the helpful information provided by other users of the community.
Posting support questions through the forums also benefits other users that may have the same issues in the future. However, if direct email support is needed, please email housebot-support@cebotics.com.
For general information, the forums are also a good place to start. For direct email inquiries, please email information@cebotics.com.
