Android remote
Spitacid
Android remote
Post by Spitacid »
Hello,
Does anyone notice theme related problems when using android OS vs a clean run of the same theme in x86/64bit remote? Can you suggest a walk around or some tips on how to resolve those issues? Thank you guys
Re: Android remote
The android themes do not display exactly as in the theme editor like the windows remotes do. This is mainly due to the differences in fonts between android and windows.
What type of problems are you seeing?
Spitacid
Re: Android remote
Post by Spitacid »
thank you for your reply.
missing bars and buttons. missing menus. "GUI On GUI" etc'.
I can upload screenshots if it helpful...
anyway, maybe we can use some walk around, do you have some tip and tricks regarding using an android device has a remote?
Re: Android remote
Other than controls and fonts not looking exactly as they do on the server theme designer, there really should be any difference between using an Android remove vs. a Windows Remote.
Every configuration is different, so if you have screen shots that show the issues or describe in detail how to reproduce it, that would be a good start.
If you are seeing a lot of problems, I would start over with something simple and then add to it slowly. That will allow you to trouble shoot each problem one at a time.
