I was playing withthe email sender, is there a way to attach a file to the emails?
What i am looking todo is email myself a webcam image when the door bell is pressed.
Email Webcam image from Housebot
Re: Email Webcam image from Housebot
Unfortunately, no. It's a pretty bare-bones email sending plugin.
It wouldn't surprise me if there was some command line email sending program somewhere that would allow attachments and you could just launch it when you needed to send.
You can use this to send emails with attachments from script within HouseBot. Please try to filter out what is needed for your setup. The attachment and email sending part should be easy to filter. This does exactly what you describe.
'- Grab Image, Create Log and EMail Image --------------
Sub Grab_DoorbellImage()
Dim MyShell
Dim CommandString
Dim ImageDateTime
Dim Image
Dim objImg
Dim iMsg
Dim iConf
Dim Flds
Const cdoSendUsingMethod = "http://schemas.microsoft.com/cdo/configuration/sendusing"
Const cdoSendUsingPort = 2
Const cdoSMTPServer = "http://schemas.microsoft.com/cdo/configuration/smtpserver"
Set MyShell = CreateObject("WScript.Shell")
Set objImg = CreateObject("ImageMagickObject.MagickImage.1")
Set iMsg = CreateObject("CDO.Message")
Set iConf = CreateObject("CDO.Configuration")
Set Flds = iConf.Fields
With Flds
.Item(cdoSendUsingMethod) = cdoSendUsingPort
.Item(cdoSMTPServer) = GetPropertyValue("EMail.Account0 Server")
.Update
End With
SetPropertyValue "News Timer.Running", "Yes"
RestoreRemote()
OpenRemotePanel("Browser")
SetPropertyValue "Browser.Start Site", "http://192.168.0.5:4716"
Sleep 5000
SetPropertyValue "Mouse Status.Action", "Login CamDVR"
Sleep 3500
SetPropertyValue "Mouse Status.Action", "Click Mouse^left,756,622,1"
Sleep 1000
ImageDateTime = L_Pad(Day(Now), 2, "0") & "-" & L_Pad(Month(Now), 2, "0") & "-" & Year(Now) & " - " & L_Pad(Hour(Now), 2, "0") & "." & L_Pad(Minute(Now), 2, "0") & "." & L_Pad(Second(Now), 2, "0")
Image = ImagePath & "Deurbel_" & ImageDateTime & ".jpg"
CommandString = """C:\Program Files\Meedio\Meedio HouseBot\Config\AutoHome\Programs\CmdCapture.exe""" & _
" /f " & """Deurbel_" & ImageDateTime & ".jpg"" /d " & """C:\Program Files\Meedio\Meedio HouseBot\Config\AutoHome\Deurbel""" & " /q 80"
Call MyShell.Run(CommandString, 0, True) 'True wacht zodat pas naar het Start Panel wordt gegaan na de grab
OpenRemotePanel("Start")
Call WriteLog("Deurbel_" & ImageDateTime)
Call objImg.Convert(Image, "-crop" ,"691x509+14+108", Image)
Sleep 2000
With iMsg
Set .Configuration = iConf
.To = GetPropertyValue("EMail.Account0 User")
.From = GetPropertyValue("EMail.Account0 User")
.Subject = "Deurbel"
.TextBody = ""
.AddAttachment Image
.Send
End With
Set Flds = Nothing
Set iConf = Nothing
Set iMsg = Nothing
Set objImg = Nothing
Set MyShell = Nothing
End Sub
Worked great thanks!
