Small caps fonts
menesi
Small caps fonts
Post by menesi »
is there any way to use small caps font type in HB, for example in a label property?
Thanks.
Laszlo Menesi
Re: Small caps fonts
Can you not just select it as a font like you would for any other font when configuring the label control?
menesi
Post by menesi »
So, because of in HB I can't set small caps attribute - only bold, italic, strikeout, underline is available - in font selection, I have to find a font type, which is originally small caps type.
Is this the solution?
Laszlo Menesi
Oh, now I understand your question. Since there is no simple checkbox for small caps in HouseBot, you will need to find a font that has something like what you are looking for. There are millions of free fonts available on the net, so hopefully you can find something acceptable. Remember that if you use a non-standard font in your theme, to be sure and copy/install it on the SWRemote machine also.
menesi
Post by menesi »
Thanks a lot.
Laszlo Menesi
