SageTV
SageTV
Is anyone using SageTV? I am integrating it into HB and would like to have some additional testers.
ericvic
Re: SageTV
Post by ericvic »
I use SageTV. What kind of integration are you doing?
Hobby Boards
Complete 1-Wire solutions
http://www.hobby-boards.com
Re: SageTV
Enable extender control from an swremote.
Display extender "Now Playing" information on swremote (including album, dvd, etc. art).
Display recent recordings on swremote.
Enable searching of media library from swremote with play now functionality.
The conduit for this will be nielm's SageTV webserver (an add-in that has been around since SageTV 2.x).
ericvic
Re: SageTV
Post by ericvic »
Sounds very interesting. I will help out as I can.
Eric
Hobby Boards
spike5884
Re: SageTV
Post by spike5884 »
Pick me! Pick me! :D
I use SageTv and love it. I started trying some integration things between SageTv & HouseBot a while back in the Meedio days, but never really got anywhere. For SageTv hardware, I have the MediaMvp, HD100, & HD200. I have nielm's webserver up and running. I also have SageTv Client and PlaceShifter. So, if you need a tester, give me a shout.
Scott J
aka spike5884
Re: SageTV
I currently have a basic script that will allow control of the extender (HD100/200 - not sure about MVP as I don't have one to develop against) over IP. In addition, it pulls the now playing data as well. This is a patchwork at the moment. I will try to get a basic script device put together this weekend and get it out to you.
Re: SageTV
Find below a .zip file with a .hbx file for import into HB. This contains three devices related to SageTV. Two of the devices allow HB to relay caller ID information and messages to the SageTV user interface via a popup using ShadeBlue's Info Popup add-in. The other device enables control of a SageTV client/extender using Nielms webserver as a conduit. To use all of these devices, the above SageTV add-ins need to be present on your SageTV server.
See the readme files for more information. Post questions, concerns, requests. The client/extender device will continue to be enhanced by me. Current functionality is quite basic...but it works.
SageTV Device File_05142009.zip
(182.05 KiB) Downloaded 625 times
