winamp multiple instances
sgcscorp
Post by sgcscorp »
Thanks for the winamp sample it really helps.
One other question is it possible to control multiple instances of winamp from housebot ?
No.
The plugin looks for a running WinAmp window in the system whenever it needs to communicate with the application. If it finds a WinAmp window running, it uses it. If it does not find one, it starts the application. So once a single instance is running, it will always use that one, even if there are multiple WinAmp Device setup.
