Weather information on your Control Panel.
Now I am sure there are other ways to do this, but me not being a coder of any sort figured this out:
To get weather info to display on your software remote screen do the following:
Find a weather service or site that has your information graphically. I used http://www.theweathernetwork.com since I am in Canada.
Find your city. Right click on the image that comes up (the one the shows temp an current conditions etc.)
Set this image as an Active Desktop item.
Make a transparent hole in your software remote panel so you can see this active desktop image, and line things up....
Voila! Active desktop automatically updates this image with your local weather info!
If anyone has a better way, I am dying to know, especially how to attach weather info to a floating panel..... With my above idea, the panel MUST remain fixed, otherwise if you move the panel, you dont see your active desktop item anymore!!!
This Idea could be used for any type of active desktop data. Sports Scores, Stocks, Etc......
Jim is working on a plugin called WeatherReport - http://www.cebotics.com/phpbb2/viewtopi ... eport#1282
I also put together a quick script to download weather data from TWC (free registration required) and display images on my remote as dynamic images. This isn't documented so you'll have to read through the code to figure out how to setup a 'Weather' device but you should get the general idea.
Click these thumbnails for bigger pictures:
' Set folder location of Weather.com icons and downloaded images
DestFolder = "c:\Program Files\HouseBot\Config\Themes\Common\weather\"
' Weather.com partner ID
WeatherComPar = "xxxxxxxx"
' Weather.com key
WeatherComKey = "xxxxxxxx
' Get weather for this postal code
WeatherComZip = "xxxxx"
Const adTypeBinary = 1
Const adSaveCreateOverWrite = 2
Const adSaveCreateNotExist = 1
Set xml = CreateObject("Microsoft.XMLHTTP")
set oStream = createobject("Adodb.Stream")
oStream.type = adTypeBinary
Set MSXML = CreateObject("MSXML.DOMDocument")
MSXML.Async = False
MSXML.preserveWhiteSpace = False
MSXML.validateOnParse = True
MSXML.resolveExternals = False
XMLURL = "http://xoap.weather.com/weather/local/" + WeatherComZip + "?cc=*&prod=xoap&par=" + WeatherComPar + "&key=" + WeatherComKey + "&dayf=5"
' Get weather images and update device properties
' (customize this for your own use)
getImage "http://image.weather.com/web/radar/us_atl_metroradar_large_usen.jpg", "W_radar"
getImage "http://image.weather.com/images/sat/regions/southeast_sat_720x486.jpg", "W_sat"
set oStream = nothing
Set xml = Nothing
Loaded = MSXML.Load(XMLURL)
If (Loaded) Then
SetPropertyValue "Weather.W_cc_lsup", MSXML.SelectSingleNode("/weather/cc/lsup").text
SetPropertyValue "Weather.W_cc_tmp", MSXML.SelectSingleNode("/weather/cc/tmp").text + "°F"
SetPropertyValue "Weather.W_cc_flik", MSXML.SelectSingleNode("/weather/cc/flik").text + "°F"
SetPropertyValue "Weather.W_cc_t", MSXML.SelectSingleNode("/weather/cc/t").text
SetPropertyValue "Weather.W_cc_icon", DestFolder + MSXML.SelectSingleNode("/weather/cc/icon").text + ".png"
SetPropertyValue "Weather.W_cc_bar_r", MSXML.SelectSingleNode("/weather/cc/bar/r").text
SetPropertyValue "Weather.W_cc_bar_d", MSXML.SelectSingleNode("/weather/cc/bar/d").text
SetPropertyValue "Weather.W_cc_wind", "From the " + MSXML.SelectSingleNode("/weather/cc/wind/t").text + " at "+ MSXML.SelectSingleNode("/weather/cc/wind/s").text + " mph"
SetPropertyValue "Weather.W_cc_hmid", MSXML.SelectSingleNode("/weather/cc/hmid").text + "%"
SetPropertyValue "Weather.W_cc_vis", MSXML.SelectSingleNode("/weather/cc/vis").text
SetPropertyValue "Weather.W_cc_uv", MSXML.SelectSingleNode("/weather/cc/uv/i").text + " " + MSXML.SelectSingleNode("/weather/cc/uv/t").text
SetPropertyValue "Weather.W_cc_dewp", MSXML.SelectSingleNode("/weather/cc/dewp").text + "°F"
SetPropertyValue "Weather.W_dayf_lsup", MSXML.SelectSingleNode("/weather/dayf/lsup").text
Set NodeList = MSXML.documentElement.selectNodes("/weather/dayf/day")
For Each Node In NodeList
SetPropertyValue "Weather.W_dayf_day" + Node.attributes.getNamedItem("d").nodeValue + "_t", Node.attributes.getNamedItem("t").nodeValue
SetPropertyValue "Weather.W_dayf_day" + Node.attributes.getNamedItem("d").nodeValue + "_dt", Node.attributes.getNamedItem("dt").nodeValue
SetPropertyValue "Weather.W_dayf_day" + Node.attributes.getNamedItem("d").nodeValue + "_hi", Node.selectSingleNode("hi").text + "°F"
SetPropertyValue "Weather.W_dayf_day" + Node.attributes.getNamedItem("d").nodeValue + "_low", Node.selectSingleNode("low").text + "°F"
set PartList = Node.selectNodes("part")
For Each Part In PartList
SetPropertyValue "Weather.W_dayf_day" + Node.attributes.getNamedItem("d").nodeValue + "_part" + Part.attributes.getNamedItem("p").nodeValue + "_icon", DestFolder + Part.selectSingleNode("icon").text + ".png"
SetPropertyValue "Weather.W_dayf_day" + Node.attributes.getNamedItem("d").nodeValue + "_part" + Part.attributes.getNamedItem("p").nodeValue + "_t", Part.selectSingleNode("t").text
SetPropertyValue "Weather.W_dayf_day" + Node.attributes.getNamedItem("d").nodeValue + "_part" + Part.attributes.getNamedItem("p").nodeValue + "_wind_s", Part.selectSingleNode("wind/s").text + "mph"
SetPropertyValue "Weather.W_dayf_day" + Node.attributes.getNamedItem("d").nodeValue + "_part" + Part.attributes.getNamedItem("p").nodeValue + "_wind_gust", Part.selectSingleNode("wind/gust").text
SetPropertyValue "Weather.W_dayf_day" + Node.attributes.getNamedItem("d").nodeValue + "_part" + Part.attributes.getNamedItem("p").nodeValue + "_wind_d", Part.selectSingleNode("wind/d").text
SetPropertyValue "Weather.W_dayf_day" + Node.attributes.getNamedItem("d").nodeValue + "_part" + Part.attributes.getNamedItem("p").nodeValue + "_wind_t", Part.selectSingleNode("wind/t").text
SetPropertyValue "Weather.W_dayf_day" + Node.attributes.getNamedItem("d").nodeValue + "_part" + Part.attributes.getNamedItem("p").nodeValue + "_ppcp", Part.selectSingleNode("ppcp").text + "%"
SetPropertyValue "Weather.W_dayf_day" + Node.attributes.getNamedItem("d").nodeValue + "_part" + Part.attributes.getNamedItem("p").nodeValue + "_hmid", Part.selectSingleNode("hmid").text + "%"
Next
Next
Sub getImage(URL, PropName)
DirArray = Split(URL, "/")
ImageFile = DirArray(UBound(DirArray))
xml.Open "GET", URL, False
xml.Send
oStream.open
oStream.write xml.responseBody
oStream.savetofile DestFolder & ImageFile, adSaveCreateOverWrite
oStream.close
SetPropertyValue "Weather." + PropName, DestFolder + ImageFile
End Sub
That is Fantastic! That is pretty much exactly what I want to do (Except that site isnt set up well for Canada)
Anyhow, Knowing absolutey nothing about scripts, I have a couple of questions:
1st, can you advise an FAQ somewhere to get the lowdown on scripting?
2nd, What type of file would that script be? I save it as an .EXE and I have tried a .JAR and it does some things when I execute it, but always comes up with errors and such......
I understand this scripting thing is a long conversation in its own self, but I certainly appreciate any knowledge that can be passed along.
- Contact:
acheslow - I agree with gorfllub - This is a great script, and I plan to use it until the plug in is ready. I have a question on the Weather device set up, though...
When you set up the device, did you add properties to HB's property list, or just use the User definable ones that are already there. From the script it looks like there are many, many properties - I'm not sure I can find that many user definable already in HB.
Would you be willing to export your Weather device and either post it here or email it to me ([email protected])?
Scott: What do you think of having a script area where people can post scripts that may be useful for those of us who either only have VBS available to us or aren't that programmatically inclined?
I'm open to changing the site to meet whatever demands HouseBot needs. There's only been a small handful of great scripts that I've seen (this is one of them). Many times the script works directly with another Device or specific Properties, so it may be better to actually do a configuration export of the Script Device (and script file). I can include the export file in the existing configuration sample section.kbosscawen wrote:Scott: What do you think of having a script area where people can post scripts that may be useful for those of us who either only have VBS available to us or aren't that programmatically inclined?
If user contributions increase, I may add a method for users to simply upload their work directly to the site. That has its advantages and disadvantages as you might be able to guess. For now, just let me know if you want to share something and send it to me.
OK here is a link to the export. Scott, feel free to download this and put it in your site somewhere. I'll continue to host it on my site as well. I hope this works out OK, please let me know if anyone has any problems or needs help.
Alan,
Thanks! I made one minor modification to the export (hope you don't mind). Your path to the script file included your machine name so the export process didn't escape it with the HouseBot path (something it does to resolve differences in file locations between different machines).
I've posted it in the configuration samples.
Thanks again.
Thanks again.
I've updated the download on my site to include a sample theme which makes use of many of the Weather device properties.
http://www.cheslow.com/modules.php?op=m ... load&cid=3
