Generic Serial Hardware Interface Plugin
Where can I find the Generic Serial Hardware Interface Plugin.
The Generic Serial plugin comes installed with HouseBot. It involves a bit more configuration than standard Plugins, since it is very customizable.
The best place to start would be by reading through the on-line help. From the HouseBot main menu, select "Help / Plugin Help...". Then select the "Generic Serial Module". It should give you a rough idea of how it works.
Plugin
Oke I find it it was not installed.
Thanks anyway.
Thanks anyway.
