WinAmp3 keeps loading coninuously
yaccri
Post by yaccri »
I'm not sure if this is a bug, but now it prevents me from using HouseBot.
I wanted to try the winamp plugin, so I downloaded the latest winamp version (3) and the HouseBot WinAmp plugin.
The problem is that apart from not playing music, it keeps trying to load WinAmp. I keep getting an error message saying:
"Unable to get handle to WinAmp window even after the process was started successfully"
So I removed the WinAmp theme from HouseBot and restarted HouseBot, but WinAmp keeps loading and the error message repeats every second or so. If I close WinAmp, It comes up again.
Maybe the problem is with the WinAmp version.
How do I prevent winamp from loading and stop this error message?
yaccri
The HouseBot WinAmp plugin works best with WinAmp version 2.x. If you want to use version 3.x, you have to install the Winamp 2x Plugin Manager component for Winamp 3. Check out the on-line help for the HouseBot WinAmp plugin for more information on this.
