Any step by step instructions out there? Where to begin? I'm unable to get the listing to work within HB.
Perhaps holiday hangover. Hmm.
Thanks!
~Michael
TV Listings
OK, yeah, im still stuck.
While configuring the XMLTV exe file, you are prompted for the area / zip code. I contunally get a mesage saying "unable to get a list of providers"etc....so I trya nother zip code. No luck. And no config file ahs been generated for me to edit. I went to Zap2it, where the codes are pulled from, and I can see my providers just fine.
I am using 0.5.15.
Perhaps zap2it ahs changed their site structure, so the older 0.5.15 version cant access the database? Has anyone else used a newer version of XMLTV with success?
Any other suggestions?
Thanks!
I am using 0.5.15.
Thanks!
OK, Downloaded 0.5.25, config worked. I then replaced the 0.5.25 with the 0.5.15 files, but kept the config file. Seems to be fine thus far.
However, I get an error in the Log in HB:
Error opening XML file...it's loking for the hblisting file in the XMLTV folder. A search on this forum says that location is configurable (?) but I dont see that. What am I missing? Thanks Scott!
In my never ending attempt to clog the board....
Downladaing 0.5.25 seems to have remedied the problem, no enabling the "get channel listing" seems to retrieve the channels into HB, so the same theme now sees the channels.
But no descriptions.
Help is apprciated (unless I solve it myself in the next 20 minutes) Ha!
~Michael
~Michael
Michael,
Whew You've been busy.
The TV Listing Device currently doesn't sort by time, only channel. I had a guest over for New Years that was asking to do the same thing (see what is on now across all channels).
I don't have any plans right now to update the TV Listing control to do this. However, if you're handy with VB Script, you could do it yourself by accessing the TV Listing database that the Control builds.
- Contact:
- Contact:
- Contact:
