HouseBot version 3.30.03 has also been released and is recommended for use with the Android remote, although older versions will still work.
For a list of changes in this version, refer to the new change log page.
I would say that the possibility of an IOS version is now much better than before.Vectrus wrote:Have you any possibility to develop a ios compatible swremote, i am happy now, tanks a lot...
I've tried to reproduce here and the sliders I have setup are working fine. Can you either send me a simple theme that shows the problem, or just give me the specific property setup for the slider that isn't working the same?Steve Horn wrote:...On the source theme, the slider's "knob" is center mid way between min and max. On the Android the "knob" is at the top. Properties are identical to the source theme - both accessing the same Winamp app on the HB server.
I have a Dell Venue and Samsung S5 that will blank the screen automatically after timeout, or by clicking the power button. On these devices, the network connection stays active (you can see the remote "in session" at the server) even though the screen is blank. This allows it to wake up without having to re-establish the connection. Not sure if there is a setting for this somewhere....There is no way to blank the screen without putting the tablet to sleep. And doing that drops the wifi link. Waking the tablet up, going into settings, turning off wifi and turning it back on forces it to reestablish the wifi connection (get IP ADDRESS, etc.). Usually, the Software remote will pick up where it left off. ...
