Exit List Bug
Exit List Bug
Hard crash with following dump after trying to edit / modify an entry in the exit list of a panel.
Go to a panels Exit List and Add a Change Property - Device, Property and Value and OK or enter. All is fine. The double click or modify this entry and press Enter or OK again. Nothing will change or HB will crash producing the following dump.
100% reproduction rate.
The only way to get around this is to delete the line and create a complete new one.
====== Begin Dump - Friday, July 13, 2007 21:37:26 ======
Server Version = 3.00.01
Thread Type = Main UI Thread
Thread ID = 1350
Fault address: 00469C9A 01:00068C9A C:\Program Files\Meedio\Meedio HouseBot\HouseBotServer.exe
Registers:
EAX:000000D0
EBX:00000000
ECX:08A410C0
EDX:00000000
ESI:166A6008
EDI:000003A5
CS:EIP:001B:00469C9A
SS:ESP:0023:0013E91C EBP:0013EC5C
DS:0023 ES:0023 FS:003B GS:0000
Flags:00050246
Call stack:
Address Frame
00469C9A 0013EC5C CxImage::`copy constructor closure'+6699A
73D423BF 0013EC8C Ordinal4424+10A
73DADEAD 0013ECB0 Ordinal4431+1D
73D43A80 0013ECE0 Ordinal4837+75
73DAD8B8 0013ED80 Ordinal4835+1A
73D41B9B 0013EDA0 Ordinal6374+24
73D41B05 0013EE00 Ordinal1109+91
73D41A58 0013EE20 Ordinal1578+36
73DD847D 0013EE4C Ordinal1579+39
7E398734 0013EE78 GetDC+6D
7E398816 0013EEE0 GetDC+14F
7E39B4C0 0013EF34 DefWindowProcW+184
7E39B50C 0013EF5C DefWindowProcW+1D0
7C90EAE3 0013EFBC KiUserCallbackDispatcher+13
7E39B903 0013EFDC SendMessageW+49
773AAB19 0013F074 Ordinal414+ADC
773E06BF 0013F0F0 Ordinal384+3481F
773E0AA6 0013F110 Ordinal384+34C06
773E14D9 0013F280 Ordinal384+35639
7E398734 0013F2AC GetDC+6D
7E398816 0013F314 GetDC+14F
7E39C63F 0013F344 IsWindowUnicode+A1
7E39F65D 0013F364 CallWindowProcA+1B
73D4216B 0013F384 Ordinal2385+44
73D41BB2 0013F3A0 Ordinal6374+3B
73D41B05 0013F400 Ordinal1109+91
73D41A58 0013F420 Ordinal1578+36
73DD847D 0013F44C Ordinal1579+39
7E398734 0013F478 GetDC+6D
7E398816 0013F4E0 GetDC+14F
7E3989CD 0013F540 GetWindowLongW+127
7E398A10 0013F550 DispatchMessageW+F
7E3AD99D 0013F574 IsDialogMessageW+DB
7E3BC69B 0013F594 IsDialogMessage+4A
73D56795 005E2F6C Ordinal4047+31
====== End Dump ======
Good one. It will be fixed in the next release.
