Question + small bug
Posted: Sun Feb 22, 2009 8:45 am
Scott;
What is 'Zorder'?
Error: script is not 'running running' is just one too many. This shouldn't be hard to find it in the code I presume.
See attached image.
Re: Question + small bug
Posted: Sun Feb 22, 2009 2:07 pm
Fixed the 'running running' thing. Thanks.
Z-Order is the layer (think 3-d: x and y being the 2-d axis and Z being front to back) that the control is in relative to the other controls in the group... really the same as the 'layer' setting on a button or image control. The theme editor tries to do some layering fixups that are necessary sometimes. Since it's a 'warning' message, it's nothing critical. I output 'warnings' that should only show up if you are specifically tracing a component. It doesn't mean that there's something necessarily wrong, but if someone is having a problem, it's sometimes nice to know anything that is out of the ordinarily that may be a factor in another problem.
Posted: Sun Feb 22, 2009 3:00 pm
Aha, layering. Something minor but a bit annoying is the high layer number I always seem to get as standard when putting an image behind buttons to create somekind of border around groups of buttons. In the theme editer I get the buttons on top but as soon as I run the swremote, the buttons are behind the image. I have to edit the theme again to layer the image behind the buttons. It would be nice if images default to 1 in the layer. Unless the high layer number is a feature. But then maybe you could elaborate a bit on why that is...
The Zorder warning mostly appears once after adding stuff to my theme and it makes sense now why that is.
Posted: Sun Feb 22, 2009 10:13 pm
Richard Naninck wrote:...It would be nice if images default to 1 in the layer. Unless the high layer number is a feature. But then maybe you could elaborate a bit on why that is...
Don't know off the top of my head. Maybe a bug.
