Any way to disable the right-click menu?
I am wondering if there is any way to disable the right-click menu? I ask because with the ViewPad when I hold the stylus (or my finger) on the screen for more than a certain amount of time it simulates a right-click. When this happens the Software Remote menu pops up.
If you were holding a button for the purposes of doing a button repeat this causes issues because the button stays down until you close the pop-up menu (you have to close the menu and then click on the button again to get it to come back up). This can lead to HIGH VOLUME levels very quickly! :-)
Sounds reasonable. :D
I figured that you could either make it a user-selectable option somehow or just remove it since you can add a button to bring up the menu if needed...
gweber
Post by gweber »
Ditto! Same issue here. *REALLY* looking forward to a possible fix for this.
Gary
P.S. Hi Dave!
That's in the next version also. Maybe the next version will be called "Dave's Version". :wink:
