Unrecognized Insteon Message Received [2]
dorrsr
Post by dorrsr »
I am getting a lot of error messages in the error log. A lot of these are "Invalid Insteon Message received Messages must start with '2' "
I also see errors such as X10 recieved HC [J] for command portion of X10, but it doesn't match last recieved HC[C}
Housebot does not always see when my bathroom fan is turned on (I have an auto off after 60 minutes). If I do a GetStatus it sees power status fine. I have no X10 devices at my home. I have 4 Insteon devices used to control 2 lights and 2 switches. The two lights work flawlessly. The 2 switches ( one is new the other was recently replaced) was working well and now is not any longer. I do not remember if it worked well prior to 3.30.01. PLM is Smarthome Powerlink Modem on serial port on a dedicated PC. Its info is: Firmware Rev 63, Deveice Category 3, Device Sub Cateogry 5.
I would love to shut off X10 in Housebot, but it appears this cannot be done.
Any ideas?
Steve Dorr
Re: Unrecognized Insteon Message Received [2]
Steve,
I suppose it could be a bad Insteon device sending incorrect messages, but it may also be noise on the line. Do the error messages occur when you would expect a normal event to be received?
Try running a hardware interface trace on the Insteon hardware interface and see what it shows.
dorrsr
Post by dorrsr »
Sorry for the delay in my response. I had not worked with Tracing before.
Here is a small section from thetrace file which shows a "bad" X10 command. Of course in my house all X10 commands are bad because I am not using any X10 components. :-)
"4/18/2009","12:10:26 pm","OfficePLM","Debug","Received Insteon Message. ID = [07.20.dc]"
"4/18/2009","12:10:26 pm","OfficePLM","Debug","Sending Subscription Notification for list [Insteon Reception]"
"4/18/2009","12:11:49 pm","OfficePLM","Debug","Character Received [0x2] ''"
"4/18/2009","12:11:49 pm","OfficePLM","Debug","Character Received [0x52] 'R'"
"4/18/2009","12:11:49 pm","OfficePLM","Debug","Character Received [0x6d] 'm'"
"4/18/2009","12:11:49 pm","OfficePLM","Debug","Character Received [0x80] '€'"
"4/18/2009","12:11:49 pm","OfficePLM","Error","X10 received HC [A] for command portion of X10, but it doesn't match last received HC [Unknown]"
"4/18/2009","12:12:56 pm","OfficePLM","Debug","Character Received [0x2] ''"
"4/18/2009","12:12:56 pm","OfficePLM","Debug","Character Received [0x52] 'R'"
"4/18/2009","12:12:56 pm","OfficePLM","Debug","Character Received [0x76] 'v'"
"4/18/2009","12:12:56 pm","OfficePLM","Debug","Character Received [0x80] '€'"
"4/18/2009","12:12:56 pm","OfficePLM","Error","X10 received HC for command portion of X10, but it doesn't match last received HC [Unknown]"
"4/18/2009","12:15:25 pm","OfficePLM","Debug","Requesting status from Address [0D.60.DB]"
"4/18/2009","12:15:25 pm","OfficePLM","Debug","Sending Command ID [0x02 62] (Send INSTEON Message) (Status Request)"
Steve,
Do these errors coincide with another actual even that is being misinterpreted? Is it safe to ignore the data?
