Features
Advanced Automation Features
  • Automatic or manually executed Tasks
  • Device / Equipment control and monitoring
  • Control programs on computer
  • Extensible through VBScript
  • Remote Control
  • Customizable Remote User Interfaces
  • Plugin architecture
System Requirements - Server
  • Microsoft Windows 98, Windows ME, Windows 2000, or Windows XP (Home, Pro, or MCE)
  • 200 MHz CPU
  • 128 MB RAM
  • 15 MB hard drive space
System Requirements - Remotes
  • Microsoft Windows CE 2.11, Windows CE 3.0, PocketPC, Windows 95, Windows 98, Windows ME, Windows NT 4.0, Windows 2000, or Windows XP (Home, Pro, or MCE). 64-bit editions of Windows XP are not yet supported.
  • 32 MB RAM
Hardware Compatibility List
     HouseBot Features
Tasks
The heart of the automation is accomplished through user configurable Tasks.
Tasks are created with a simple point-and-click task wizard to set up sophisticated events without any manual programming.
Tasks allow monitoring and control over any Device setup in the HouseBot system.
(hold mouse over for large image)
Device / Equipment Control
All physical devices that need to be controlled or monitored are setup in the system as 'Devices'. These Devices have properties that reflect their current state and allow HouseBot to control them. The properties that a device has depend on the abilities of the device and define what can be monitored and controlled. For example, to turn on the "kitchen under the counter light" device, simply change the "Power State" property of the "Kitchen Under Counter Light" (or whatever name you wish to give it) to "On". This will cause the light to turn on.
In addition to controlling physical devices such as switches, HouseBot can also control Software Devices. Software Devices are simply software applications running on the HouseBot server that can be monitored and controlled in the same way that physical devices are monitored and controlled.  Both types of Devices contain properties and are controlled exactly the same.
HouseBot supports a growing list of automation interfaces and software.  Click here to see a quick list of things that can be controlled, or check out the hardware compatibility page.  You are not confined to a single hardware interface or protocol for automating your home.  HouseBot can control and monitor equipment from a variety of manufacturers in the same way.  For example, you can have an X10 wireless motion detector trigger a task that will turn on Z-Wave lights.
Remote Control - Software Remotes
Software Remote user interfaces are constructed by simple drag-and-drop editing to create interactive (2-way) control panels of the HouseBot system.
Software remotes run as native applications on a variety of Windows, Windows CE, and PocketPC platforms — no clunky web browsers required.
Run your themes on "software remotes" for real-time monitoring and control of your HouseBot Devices through wired or wireless PCs, PDAs, tablet PCs, and touchscreens.
