HouseBot Server
The server application is compatible
with most of the current Windows operating systems including:
- Windows 2000
- Windows XP
- Windows Vista
The minimum hardware requirements to run the HouseBot server
are a 200MHz CPU and 128MB of RAM. However, the actual
hardware requirements will depend on how extensively the
system is configured. The server is generally idle and
can coexist with other applications on the server.
Software Remotes
Software Remotes are compatible with
almost any Windows operating systems including:
- Windows CE 2.11
- Windows CE 3.0
- Windows CE 5.0
- PocketPC
- Windows 95
- Windows 98
- Windows ME
- Windows NT 4.0
- Windows 2000
- Windows XP
- Windows Vista
Server Hardware Interface Compatibility
The HouseBot server machine can connect to a wide variety of
hardware interfaces for automation of any type. The
following list are the hardware interfaces that are included
with HouseBot. The Software Development Kits (SDKs)
can be used to create custom Hardware Interfaces
allowing HouseBot to connect to virtually any equipment.
- Generic Serial - The Generic Serial hardware interface
provides a configurable method to send and receive data to
the RS232/COM port. It can be customized to
communicate with a wide variety of RS232 attached equipment.
- ADI
Ocelot /
Leopard - X10 (2-way), Infrared (2-way), Relay, Input
monitor.
Global Cache GC-100 / GC-IRE - RS-232 (2-way),
Infrared (2-way), Relay, Digital Input monitor.
- Modem / Phone - Any RS232 modem that supports caller ID
for incoming call detection and caller ID information.
NetCallerID - Incoming call detection and caller ID
information.
PowerLinc USB - X10 USB controller (2-way).
- Insteon PowerLinc
USB /
Serial - X10 (2-way), Insteon (2-way). Requires
SmartHome Device Manager software.
Insteon PowerLinc Modem - Insteon (2-way)
Slink-e - Infrared (2-way) - This product is now
obsolete.
USB-UIRT - Infrared (2-way) - USB attached controller.
W800 - Receive RF X10 signals - RS232 attached.
- X10
CM11a, CM11g - X10 (2-way)
X10 MR26a - Receive RF X10 signals - RS232 attached.
Firecracker / CM17a - Control X10 Devices using RF
ACT ZCU000 / ZCU001 - Z-Wave. Obsolete
- Z-Wave Serial - Support for
ACT ZCS series controllers.
- Z-Wave USB - Support for
Intermatic HA22,
Wayne Dalton WD HD-10 USB controller and all
branded versions, and
ACT ZCU series controllers.
