How can I change the default font in the Theme Editor
You can customize your own controls and save them as your own private Skin. This allows you to quickly select from control styles that you use often.
Here is a quick description of how to setup you own Skin. Refer to the on-line help for more information on Skins.
  1. Create a Theme that contains all of the controls using the styles (fonts, images, etc) you commonly use. The controls don’t all have to be on one panel. You can either copy panels and controls from existing Themes, or simply use an existing Theme that uses most of what you want in the new Skin.
  2. With the Theme selected, select “Theme/Save Theme To Skin…” from the main menu.
  3. Click the ‘Create New Skin’ button.
  4. Give the Skin a name and press the OK button.
Now when selecting controls in the Theme Editor, you can select your new Skin from the other HouseBot Skins.[/list]
