Response: " Hmmm <device name> is not responding."
All software remote functions work, HB server running, my.housebot.com appears normal and functional. Restarted HB server. Same result.
As Alexa says, "Hmmmm"
"Alexa, turn off <device name>"
Re: "Alexa, turn off <device name>"
Oops. I've been production testing the new Alexa HouseBot skill that uses their newer version 3 API today. You were still setup as a tester on the account, so you were getting the new V3 skill although your HouseBot only works with V2. Sorry about that.
I've removed you from the testing list. I would suggest you disable the skill and add it back and re-discover. That should get you back to V2.
FYI, I'll be releasing a new HouseBot in the next day or two that supports the V3 API.
