HB 3.41 serial port identification
Posted: Sat Feb 11, 2017 6:23 pm
Scott, That change you made to the current release seems to improve on the assignment of serial ports in the hardware interface. The "labeling" seems to agree with what is seen in Win Device Manager. But... I just ran into an issue that may be peculiar enough to not have been accounted for in whatever you did. I have a "genuine" Arduino that when plugged into a USB port is identified by Windows in Device Manager as as "Arduino UNO", which it is. And that port number and literal also appears in HB. I just added a second Arduino, although this one is a generic non-genuine Arduino, specifically a Sparkfun Redboard, which is 100% compatible with the genuine Arduinos. When I plug it into the HB computer via USB it is assigned a port number and is labeled as a "USB Serial port". But when I tried to assign that port in HB that port is not listed in the dropdown. Another "Genuine" Arduino Uno (which is being replaced by this Redboard) was assigned COM10 without any assignment issues in HB. But Windows DM has the new board as COM9. which does not appear in HB. The quick solution was to reassign the port/device in Device Manager from COM9 to COM10. Now HB agrees with Windows and the device can be talked to by HB. The only thing that I know to be different between the "Genuine" Arduino Uno and the Redboard is the USB serial driver is FTDI. When I look at the Properties of the Arduino in Win DM, it shows that its driver/manufacturer is Arduino, which is correct. (If I recall correctly, the first Arduino added to the PC must install an Arduino-specific USB driver.) When I look at the properties of the Redboard, it shows the driver manufacturer as FTDI. I have no idea whether the fact that this device uses an FTDI driver affects how you/HB identifies ports available for assignment in the Hardware Interface.
