Property Substitution Issue
I'm having an issue using property substitution when there is a hyphen in the property name. (i.e., %%UPB-0B.Dim Level%%) Is there any way to get around this without renaming the property -- that would be painful.
Re: Property Substitution Issue
I'm not able to replicate that. I have the following task and it seems to work.
- HouseBot_2016-10-02_15-56-33.png (1.98 KiB) Viewed 2786 times
Maybe because I'm using it inside a string. It works fine in other places using the same methodology.
Unable to find Device with Description [UPB-* ERROR *]
Found it. It is actually an error in my script and not HB.
