Crash
jacco van der Ven
Crash
Post by jacco van der Ven »
Last week I had an power interupt, after this HouseBot is crashing randomly. Before it was running fine.
What can I do about it?
Jacco.
This is the message dump.
====== Begin Dump - Saturday, October 25, 2014 09:57:29 ======
Server Version = 3.30.02
Fault address: 7862FBA7 01:0004EBA7 C:\WINDOWS\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.6161_x-ww_028BC148\mfc90.dll
Registers:
EAX:1867FAAC
EBX:1857FE9C
ECX:1857FED0
EDX:78507308
ESI:1857FED0
EDI:1857FEC4
CS:EIP:001B:7862FBA7
SS:ESP:0023:1867FA74 EBP:1867FB48
Flags:00010206
Call stack:
Address Frame
7862FBA7 1867FB48 Ordinal2327+5
15D99E18 7D1F73A2 0000:00000000
Re: Crash
Jacco,
Unfortunately that dump file doesn't point to the problem.
However, if it started happening right after the power was cut, my guess would be that the config file became corrupted. I would suggest copying the last backup you have. If you don't have a recent backup, there will be an HBData.autobackup.mdb file that HouseBot creates. There's more info on this in the HouseBot help (Backing up the Configuration), but basically you just stop HouseBot and copy the MDB file from the Config\Backup directory to the Config directory and name it HBData.mdb.
jacco van der Ven
Re: Crash
I installed the backup on a new PC and everyting is working well, I think there is something wrong with my old PC :(
