I was going to post this in the vbscript section, but it's locked and can't workout how to post to the main scripts section on the website? anyway...
UK Train Departures
Works with the following uk train operators (I have it working with c2c)
c2c, Chiltern Railways, East Coast, First Capital Connect, First Great Western, First ScotRail, Greater Anglia, London Midland, London Overground, South West Trains, Southeastern, Southern, Transpennine Express
The URL in the script is constructed as follows
http://pda.jcheck.com/[TRAIN OPERATOR]/route?from=[STATION]&type=departures
You will require a device in housebot with the follow names: Train Departures.Train 1, Train Departures.Train 2, Train Departures.Train 3, Train Departures.Train 4.
On Error Resume Next
call SetPropertyValue("Train Departures.Train 1","Updating...")
call SetPropertyValue("Train Departures.Train 2","Updating...")
call SetPropertyValue("Train Departures.Train 3","Updating...")
call SetPropertyValue("Train Departures.Train 4","Updating...")
Dim objXmlHttp
Set objXmlHttp = CreateObject("Msxml2.XMLHttp")
objXmlHttp.Open "POST", "http://pda.jcheck.com/c2c/route?from=Stanford-Le-Hope&type=departures", False
objXmlHttp.Send
Dim sContent
Dim sDep1
Dim sDep2
Dim sDep3
Dim sDep4
sContent = objXmlHttp.responseText
if InStr(sContent,"There are no services departing from")<>0 then
sDep1 = "There are no services departing within the next hour."
else
sContent = Mid(sContent,InStr(sContent,"secondaryHeadingRow"))
'DEPT 1
sContent = Mid(sContent,InStr(sContent,"scheduled")+24)
sDep1 = Mid(sContent,1,InStr(sContent,"</td>")-1) & " - "
sContent = Mid(sContent,InStr(sContent,"expected")+23)
sDep1 = sDep1 & Mid(sContent,1,InStr(sContent,"</td>")-1) & " - "
sContent = Mid(sContent,InStr(sContent,"DESTINATION")+44)
'DEPT 2
sDep2 = Mid(sContent,1,InStr(sContent,"</td>")-1) & " - "
sDep2 = sDep2 & Mid(sContent,1,InStr(sContent,"</td>")-1) & " - "
'DEPT 3
sDep3 = Mid(sContent,1,InStr(sContent,"</td>")-1) & " - "
sDep3 = sDep3 & Mid(sContent,1,InStr(sContent,"</td>")-1) & " - "
'DEPT 4
sDep4 = Mid(sContent,1,InStr(sContent,"</td>")-1) & " - "
sDep4 = sDep4 & Mid(sContent,1,InStr(sContent,"</td>")-1) & " - "
end if
call SetPropertyValue("Train Departures.Train 1",sDep1)
call SetPropertyValue("Train Departures.Train 2",sDep2)
call SetPropertyValue("Train Departures.Train 3",sDep3)
call SetPropertyValue("Train Departures.Train 4",sDep4)
Set objXmlHttp = Nothing
If Err.Number <> 0 Then
TraceErrorMessage( "Script error in internet_feeds_c2c.vb : " & Err.Description )
Err.Clear
When the phone rings, I have this script lookup the phone number in my google account, as this is the same account as my android phone.
GoogleEmail = "[email protected]"
GooglePassword = "PASSWORD"
CountryCode = "0044"
HouseBotPhoneNumberProperty = "Phone.Last Phone Number" ' Device in housebot that has phone number to lookup
HouseBotLogProperty = "House Event.Message" ' Device in housebot that will report back the phone number in housebot
Set objHTTP = CreateObject("Microsoft.XMLHTTP")
objHTTP.Open "POST", "https://www.google.com/accounts/ClientLogin", FALSE
objHTTP.SetRequestHeader "Content-Type", "application/x-www-form-urlencoded"
objHTTP.Send "Email=" + GoogleEmail + "&Passwd=" + GooglePassword + "&service=cp&source=HouseBotScript"
If objHTTP.status <> 200 Then
TraceErrorMessage ("Error with /accounts/ClientLogin: " & objHTTP.statusText )
Else
'Get authentication string for the /m8/feeds/contacts call to google
strAuthTokens = objHTTP.ResponseText
strAuthTokens = Replace(strAuthTokens, vbCr, "")
strAuthTokens = Replace(strAuthTokens, vbLf, "")
strAuthTokens = Replace(strAuthTokens, vbCrLf, "")
strAuthTokens = Replace(strAuthTokens, "SID", "&SID", 1, 1)
strAuthTokens = Replace(strAuthTokens, "LSID", "&LSID")
strAuthTokens = Replace(strAuthTokens, "Auth", "&Auth")
strAuthTokens = Right(strAuthTokens, Len(strAuthTokens)-Len("Auth=")-InStr(strAuthTokens, "Auth=")+1)
'Get contacts from google
objHTTP.Open "GET", "https://www.google.com/m8/feeds/contacts/default/full?max-results=999", FALSE
objHTTP.SetRequestHeader "Authorization", "GoogleLogin auth=" & strAuthTokens
objHTTP.Send
'If successful will go off and find the name
TraceErrorMessage ("Error with /m8/feeds/contacts: " & objHTTP.statusText)
Else
call SetPropertyValue(HouseBotLogProperty, "Phone call from " & FindContactUsingPhoneNumber(objHTTP.responseText,GetPropertyValue( HouseBotPhoneNumberProperty ) ) )
Set objHTTP = Nothing
'Log any errors to HouseBot
'Add HouseBot Error Logging
TraceErrorMessage ( Err.Description )
'Function steps though google contacts and if there us a match returns the name, otherwise it will return number
Function FindContactUsingPhoneNumber(xmlToSearch, phoneNumber)
'Set the return as the phone number, just in case if does not find anything and needs to return something
FindContactUsingPhoneNumber = phoneNumber
'Remove while space from phone number
phoneNumber = Replace(phoneNumber," ","")
Set objXml = CreateObject("Microsoft.XMLDOM")
objXml.async = false
objXml.loadxml (xmlToSearch)
'Step through each google contact
For Each NodeEntriy in objXml.selectNodes("/feed/entry")
Set objXmlEntry = CreateObject("Microsoft.XMLDOM")
objXmlEntry.async = false
objXmlEntry.loadxml (NodeEntriy.xml)
'Step through each phone numbber in the selected contact
For Each NodePhoneNumbers in objXmlEntry.selectNodes("//gd:phoneNumber")
NumberToMatch = NodePhoneNumbers.text 'Tidy up phone number so it can be matched
NumberToMatch = Replace(NumberToMatch," ","") ' Remove whitespace
NumberToMatch = Replace(NumberToMatch,"++","00")
NumberToMatch = Replace(NumberToMatch,"+","00") ' Remove international ++ and replace with 00, same as callerid modem displays
If Instr(NumberToMatch,CountryCode) = 1 Then NumberToMatch = "0" & Mid(NumberToMatch,Len(CountryCode)+1) ' Removes CountryCode from phone numbers that are withing the same country
'See if the numbers match, if so return name and exit function
If phoneNumber = NumberToMatch Then
FindContactUsingPhoneNumber = objXmlEntry.selectSingleNode("//title").text
FindContactUsingPhoneNumber = FindContactUsingPhoneNumber & " " & Replace(NodePhoneNumbers.getAttribute("rel"),"http://schemas.google.com/g/2005#","")
Exit Function
Next
Set objXmlEntry = Nothing
Next
Set objXml = Nothing
End Function
TraceErrorMessage( "Script error in phone_lookup_google.vb : " & Err.Description )
Err.Clear
