CM11 dead?
Posted: Thu Aug 05, 2010 7:27 am
by sundodger
Before i go and buy a new interface let me run this error by the experts. Keep getting Checksum returned from CM11 is not correct return = a5 expected 32.
Sometimes i get expected 67.
Any Thoughts?
Re: CM11 dead?
Posted: Fri Aug 06, 2010 8:34 am
The CM11 will keep sending an 'a5' response to the interface if it has detected a power failure. The interface handles this by resetting the clock and responding correctly. You might want to check to make sure your CM11 battery is still good.
Re: CM11 dead?
Posted: Fri Aug 06, 2010 1:42 pm
by sundodger
Put fresh batteries in to be sure. But get the same error.
Just keeps trying to send X10 command and gives the message over and over.
Re: CM11 dead?
Posted: Sat Aug 07, 2010 10:02 am
Maybe try running the software that came with the CM11 to see if it either fixes the problem (somehow) or provides more info on what the problem is.
http://www.smarthome.com/1140/X10-Activ ... 11A/p.aspx
You could also try running a
hardware interface trace to see if that reveals anything additional.
Re: CM11 dead?
Posted: Sun Aug 15, 2010 3:29 pm
by sundodger
so what did i do. put housebot onto a machine with a serial port. eventually got activehome talking to the interface, housebot also.
tried both through usb to serial converter and no good.
Dont know why the converter worked for a while and then stopped but it did.
Housebot will have to reside on this PC for the time being.
On to the next problem....
