Global Cache - GCIRE connects on wrong module
jaga01
Post by jaga01 »
I have an Global Cache attached to my hb. I am trying to establish connection with my GCIRE that is connected to the one and only rs232 connector on the GC. I have tested the ability to learn ir codes with the GC utility and it works without problems. When i try from within HB it seems that it connects as module 0 instead of module 1. I cant find a place to change this because in the drop down the choices is only Com0 and None.
I have had it running and working for a short period. Then suddenly it changed and I could do nothing.
In the middle splash star up screen information area in HB the following information is given:
"Incorrect Device ID (Device,GC-IRL) Found"
Does anyone have an idea of what to do and what happens?
BRDGS,
Jacob
