What is the easiest and best mail service to use with the SMTP device. I notice it has no way to change ports, use SSL, etc. so I don't imagine it works with very many services. What are folks using?
Thanks, Jay
Easiest way to send mail
Re: Easiest way to send mail
Try the ostrosoft component and add an email account to your current ISP.
Option Explicit
Dim oSMTP 'As OSSMTP.SMTPSession
Set oSMTP = CreateObject("OSSMTP.SMTPSession")
oSMTP.Server = "smtp-server.myISP.com" 'SMTP server name or IP address
oSMTP.POPServer = "pop-server.myISP.com"
oSMTP.Port = 25
oSMTP.MailFrom = "HouseBot [email protected]" 'sender e-mail address
oSMTP.SendTo = "[email protected]" 'recipient e-mail address
oSMTP.AuthenticationType = 1 '0 = AuthNone, 1 = AuthPOP, 2 = AuthLogin, 3 = AuthPlain
oSMTP.Username = "HouseBot Server" 'name for mailserver authentication
oSMTP.Password= "mypwd" 'password for mailserver authentication
oSMTP.MessageSubject = "mySubject" 'message subject or use GetPropertyValue(".MySubject") to retrieve a property from HB
oSMTP.MessageText = GetPropertyValue("myDevice.myProperty") 'message text or use GetPropertyValue(".MyText") to retrieve a property from HB
oSMTP.RaiseError = True
oSMTP.SendEmail
Set oSMTP = Nothing
any way to send an attachment as well using ostrosoft?
I use OSPOP3 for receiving emails but use a different form for sending emails. HouseBot can't send attachments so I had to look for another way to send a doorbell picture to my iPhone.
Looks like there is a newer version of this software called OSSMTP_Plus that handles SSL, attachments, and some other stuff.
I have not had any luck with the SSL stuff using my normal gmail accounts or the yahoo plus accounts that need SSL.
I did get it to work with the old yahoo smtp servers on port 25.
I guess thats what I'll use for now.
I use a command line program called POSTIE.
The free version has some limitations but works well. I have been using it for years.
http://www.infradig.com/postie/
v.r
v.r
I use this:
Dim iMsg
Dim iConf
Dim Flds
Const cdoSendUsingMethod = "http://schemas.microsoft.com/cdo/configuration/sendusing"
Const cdoSendUsingPort = 2
Const cdoSMTPServer = "http://schemas.microsoft.com/cdo/configuration/smtpserver"
Set iMsg = CreateObject("CDO.Message")
Set iConf = CreateObject("CDO.Configuration")
Set Flds = iConf.Fields
With Flds
.Item(cdoSendUsingMethod) = cdoSendUsingPort
.Item(cdoSMTPServer) = GetPropertyValue("EMail.Account0 Server")
.Update
End With
'------------- Do your thing here...
With iMsg
Set .Configuration = iConf
.To = GetPropertyValue("EMail.Account0 User")
.From = GetPropertyValue("EMail.Account0 User")
.Subject = "Deurbel"
.TextBody = ""
.AddAttachment Image
.Send
End With
Set Flds = Nothing
Set iConf = Nothing
Set iMsg = Nothing
