Lots of vbscript related crashes
I am having multiple crashes per day. Not sure what is going on. Scott, can you look at the dump file and see if there are any clues?
====== Begin Dump - Monday, July 20, 2009 16:24:08 ======
Server Version = 3.30.02
Fault address:  7869C8DA 01:000BB8DA C:\WINDOWS\WinSxS\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_405b0943\mfc90.dll
Registers:
EAX:1362FE98
EBX:00000000
ECX:00000001
EDX:00000000
ESI:005B7190
EDI:00000000
CS:EIP:001B:7869C8DA
SS:ESP:0023:1396F88C  EBP:1396F914
DS:0023  ES:0023  FS:003B  GS:0000
Flags:00010286
Call stack:
Address   Frame
7869C8DA  1396F914  Ordinal4274+400
73313A78  1396F95C  DllGetClassObject+6D92
733139F6  1396FA70  DllGetClassObject+6D10
73306801  1396FA94  DllCanUnloadNow+154F
73304D16  1396FD6C  0001:00003D16 C:\WINDOWS\System32\vbscript.dll
73301E55  1396FE70  0001:00000E55 C:\WINDOWS\System32\vbscript.dll
73303A76  1396FED4  0001:00002A76 C:\WINDOWS\System32\vbscript.dll
7330BE2A  1396FF24  DllCanUnloadNow+6B78
73314DCF  1396FF40  DllGetClassObject+80E9
0046817C  1396FFAC  CxIOFile::~CxIOFile+651FC
7854332B  1396FFB4  endthread+DA
7C80B683  1396FFEC  GetModuleFileNameA+1B4
====== End Dump ======
====== Begin Dump - Monday, July 20, 2009 16:24:59 ======
Fault address:  77124975 01:00003975 C:\WINDOWS\system32\OLEAUT32.dll
Registers:
EAX:1362FEA8
EBX:00000000
ECX:00001C58
EDX:00000030
ESI:1396FE1C
EDI:00000009
CS:EIP:001B:77124975
SS:ESP:0023:1396EFF8  EBP:1396F004
Flags:00010202
Call stack:
Address   Frame
77124975  1396F004  VariantClear+55
733015BB  1396F02C  0001:000005BB C:\WINDOWS\System32\vbscript.dll
73301EE9  1396FD6C  0001:00000EE9 C:\WINDOWS\System32\vbscript.dll
====== Begin Dump - Monday, July 20, 2009 16:37:45 ======
Registers:
EAX:12FBFE98
EBX:00000000
ECX:00000001
EDX:00000000
ESI:005B7190
EDI:00000000
SS:ESP:0023:130BF88C  EBP:130BF914
Flags:00010286
Call stack:
Address   Frame
7869C8DA  130BF914  Ordinal4274+400
73313A78  130BF95C  DllGetClassObject+6D92
733139F6  130BFA70  DllGetClassObject+6D10
73306801  130BFA94  DllCanUnloadNow+154F
73304D16  130BFD6C  0001:00003D16 C:\WINDOWS\System32\vbscript.dll
73301E55  130BFE70  0001:00000E55 C:\WINDOWS\System32\vbscript.dll
73303A76  130BFED4  0001:00002A76 C:\WINDOWS\System32\vbscript.dll
7330BE2A  130BFF24  DllCanUnloadNow+6B78
73314DCF  130BFF40  DllGetClassObject+80E9
0046817C  130BFFAC  CxIOFile::~CxIOFile+651FC
7854332B  130BFFB4  endthread+DA
7C80B683  130BFFEC  GetModuleFileNameA+1B4
====== Begin Dump - Monday, July 20, 2009 16:44:34 ======
Registers:
EAX:0159FE98
EBX:00000000
ECX:00000001
EDX:00000000
ESI:005B7190
EDI:00000000
SS:ESP:0023:12C3F88C  EBP:12C3F914
Flags:00010286
Call stack:
Address   Frame
7869C8DA  12C3F914  Ordinal4274+400
73313A78  12C3F95C  DllGetClassObject+6D92
733139F6  12C3FA70  DllGetClassObject+6D10
73306801  12C3FA94  DllCanUnloadNow+154F
73304D16  12C3FD6C  0001:00003D16 C:\WINDOWS\System32\vbscript.dll
73301E55  12C3FE70  0001:00000E55 C:\WINDOWS\System32\vbscript.dll
73303A76  12C3FED4  0001:00002A76 C:\WINDOWS\System32\vbscript.dll
7330BE2A  12C3FF24  DllCanUnloadNow+6B78
73314DCF  12C3FF40  DllGetClassObject+80E9
0046817C  12C3FFAC  CxIOFile::~CxIOFile+651FC
7854332B  12C3FFB4  endthread+DA
7C80B683  12C3FFEC  GetModuleFileNameA+1B4
====== Begin Dump - Monday, July 20, 2009 16:51:28 ======
Fault address:  00467135 01:00066135 C:\Program Files\HouseBot\HouseBotServer.exe
Registers:
EAX:1241F7B4
EBX:00000000
ECX:1231FE98
EDX:11683CDC
ESI:1241F7C0
EDI:00000008
CS:EIP:001B:00467135
SS:ESP:0023:1241F7AC  EBP:1241F870
Flags:00010286
Call stack:
Address   Frame
00467135  1241F870  CxIOFile::~CxIOFile+641B5
7869C862  1241F914  Ordinal4274+388
73313A78  1241F95C  DllGetClassObject+6D92
733139F6  1241FA70  DllGetClassObject+6D10
73306801  1241FA94  DllCanUnloadNow+154F
733174BB  1241FD6C  DllGetClassObject+A7D5
73301E55  1241FE70  0001:00000E55 C:\WINDOWS\System32\vbscript.dll
73303A76  1241FED4  0001:00002A76 C:\WINDOWS\System32\vbscript.dll
7330BE2A  1241FF24  DllCanUnloadNow+6B78
73314DCF  1241FF40  DllGetClassObject+80E9
0046817C  1241FFAC  CxIOFile::~CxIOFile+651FC
7854332B  1241FFB4  endthread+DA
7C80B683  1241FFEC  GetModuleFileNameA+1B4
====== Begin Dump - Monday, July 20, 2009 18:40:30 ======
Registers:
EAX:10F1FE98
EBX:00000000
ECX:00000001
EDX:00000000
ESI:005B7190
EDI:00000000
SS:ESP:0023:12BAF88C  EBP:12BAF914
Flags:00010286
Call stack:
Address   Frame
7869C8DA  12BAF914  Ordinal4274+400
73313A78  12BAF95C  DllGetClassObject+6D92
733139F6  12BAFA70  DllGetClassObject+6D10
73306801  12BAFA94  DllCanUnloadNow+154F
73304D16  12BAFD6C  0001:00003D16 C:\WINDOWS\System32\vbscript.dll
73301E55  12BAFE70  0001:00000E55 C:\WINDOWS\System32\vbscript.dll
73303A76  12BAFED4  0001:00002A76 C:\WINDOWS\System32\vbscript.dll
7330BE2A  12BAFF24  DllCanUnloadNow+6B78
73314DCF  12BAFF40  DllGetClassObject+80E9
0046817C  12BAFFAC  CxIOFile::~CxIOFile+651FC
7854332B  12BAFFB4  endthread+DA
7C80B683  12BAFFEC  GetModuleFileNameA+1B4
Re: Lots of vbscript related crashes
Most of the exceptions are in other modules, so I can't really make too much of it. However, the one that is in HouseBot *seems* to be in the GetPropertyValue call. I can't really tell much more due to the nature of the call, however, if you have made any script changes regarding that particular call (I know it's a pretty popular function), it might be a good place to start.
Thanks! I have made some dramatic changes to my sonos script so I will shut it down and see if that resolves the problem. If so....well, I guess I have some work to do.
