HB dumps during UIRT IR Learning
HB dumped three times while reading around 30 IR codes.
See dums below. There was no pattern or good method to replicate this dump so hopefully the dump itself tells you anything.
====== Begin Dump - Saturday, March 07, 2009 21:03:58 ======
Server Version = 3.30.01
Fault address: 00000000 1EA3F7D0:775C1E6A
Registers:
EAX:00000000
EBX:00007530
ECX:7C802600
EDX:7C90E4F4
ESI:1B321960
EDI:7C802550
CS:EIP:001B:00000000
SS:ESP:0023:1EA3FF98 EBP:1EA3FFB4
Flags:00010246
Call stack:
Address Frame
00000000 1EA3FF94 0000:00000000
774BE3EE 1EA3FFB4 StringFromGUID2+5DC
7C80B713 1EA3FFEC GetModuleFileNameA+1B4
====== End Dump ======
====== Begin Dump - Saturday, March 07, 2009 21:07:09 ======
Fault address: 00000000 1CF6F7D0:775C1E6A
Registers:
EAX:00000000
EBX:00007530
ECX:7C802600
EDX:7C90E4F4
ESI:19ECA5E8
EDI:7C802550
SS:ESP:0023:1CF6FF98 EBP:1CF6FFB4
Flags:00010246
Call stack:
Address Frame
00000000 1CF6FF94 0000:00000000
774BE3EE 1CF6FFB4 StringFromGUID2+5DC
7C80B713 1CF6FFEC GetModuleFileNameA+1B4
====== Begin Dump - Saturday, March 07, 2009 21:15:40 ======
Fault address: 00000000 138AF7D0:775C1E6A
Registers:
EAX:00000000
EBX:00007530
ECX:7C802600
EDX:7C90E4F4
ESI:158D09B0
EDI:7C802550
SS:ESP:0023:138AFF98 EBP:138AFFB4
Flags:00010246
Call stack:
Address Frame
00000000 138AFF94 0000:00000000
774BE3EE 138AFFB4 StringFromGUID2+5DC
7C80B713 138AFFEC GetModuleFileNameA+1B4
Re: HB dumps during UIRT IR Learning
Richard,
Usually there is a module file name after that numeric "Fault Address" shown in the dump. These dumps just have a symbol, so I'm not sure if that is truly missing, or if something was lost in the translation. If there is a module name, can you let me know what it is?
Just looked at the dumps and there is just a single character (hex 10) where you would expect the module name. On the same day (about half an hour after the last dump I posted) I see another dump. Shown below. I cannot tell if this dump was caused by the same IR learning process the above posted dumps were created so this is probably nothing extra to get you going.
====== Begin Dump - Saturday, March 07, 2009 21:46:46 ======
Thread Type = Main UI Thread
Thread ID = CE0
Fault address: 0043290F 01:0003190F C:\Program Files\Meedio\Meedio HouseBot\HouseBotServer.exe
Registers:
EAX:26F0F7E0
EBX:00000001
ECX:0062FE90
EDX:00000002
ESI:00000000
EDI:0062FE90
CS:EIP:001B:0043290F
SS:ESP:0023:0012F25C EBP:0012F284
Flags:00050202
Call stack:
Address Frame
0043290F 0012F284 CxIOFile::~CxIOFile+2F98F
7866971E 0012F2A0 Ordinal4667+124
786416A7 0012F2E0 Ordinal4671+7E
7863C2AB 0012F330 Ordinal4688+92
78640B70 0012F34C Ordinal4683+7B
7863BAA6 0012F3F8 Ordinal5497+66
7863BA19 0012F418 Ordinal6780+24
7863A60D 0012F480 Ordinal1066+A3
7863A899 0012F4A4 Ordinal1278+37
78638594 0012F4EC Ordinal606+196
7E398734 0012F518 GetDC+6D
7E398816 0012F580 GetDC+14F
7E3989CD 0012F5E0 GetWindowLongW+127
7E3996C7 0012F5F0 DispatchMessageA+F
7867A75E 0012F620 Ordinal1161+40
004311AA 0012F650 CxIOFile::~CxIOFile+2E22A
78647202 0012F664 Ordinal1276+6A
0056D06A 0012F6F4 CxIOFile::~CxIOFile+16A0EA
003B0BD0 0012F774 0000:00000000
0065ADE6 0012FED8 0004:00028DE6 C:\Program Files\Meedio\Meedio HouseBot\HouseBotServer.exe
0065AE8C 0012FEE0 0004:00028E8C C:\Program Files\Meedio\Meedio HouseBot\HouseBotServer.exe
0065B6AA 0012FF0C 0004:000296AA C:\Program Files\Meedio\Meedio HouseBot\HouseBotServer.exe
0066F1D9 0012FF98 0004:0003D1D9 C:\Program Files\Meedio\Meedio HouseBot\HouseBotServer.exe
00682000 00682000 0004:00050000 C:\Program Files\Meedio\Meedio HouseBot\HouseBotServer.exe
505D0000 0000E860 0000:00000000
