urgent bug
peter
urgent bug
Post by peter »
try to set a numeric property by a task. The task copies a numeric value from any other property (%%_%%).
When you set the original property to any negative value for instance -1 the destination property becomes -4 (always four times of the original one).
This was not in HB3.01.
peter
I was able reproduce this problem. Works fine, except for PV substitution. I've not had a chance to diagnose, but there should be a fix in the next release. In the interim, you could probably use a script to do the assignment.
