HouseBot 2.32 has been released
I was planning on version 2.31 to be the last for a while to allow me the opportunity to focus on some longer term enhancements. However, a fairly serious problem was discovered that could make the system unstable in certain circumstances. So I decided to go ahead and release this minor update containing the fix.
The problem would only be evident if you had property values that exceeded 100 bytes (most don't). The symptoms of the problem would be misleading because they would show as faults in other HouseBot modules/plugins and would not point to the true culprit.
