- New: Support for Bond Bridge Fan Controller.
- New: Web View Theme control for displaying websites on Software Remotes.
- New: New Theme control button type for controlling the Web View (Forward, Backward, Refresh, Stop, Zoom In/Out)
- Minor ZWave fixes.
What's new in HouseBot (Watch this topic for updates)
Version 3.55 has been released
Version 3.55 has been released with the following changes.
Version 3.56 has been released
Version 3.56 has been released with the following changes.
- New HotKey Device Plugin.
- Updated the MQTT Hardware Interface to use the latest mqtt support files.
- MQTT: Now will automatically reconnect if the connection is lost.
- Fixed an issue where task conditions with substitution values may be replaced with actual values.
- Fixed an issue where non-existent mode referenced in task blocks would cause the prior item to be duplicated.
- Add a client control options for 'Always on Top' and 'Not Always on Top'.
- Increased the receive buffer size for Node-Red.
- Fixed issue when adding ‘temperature’ properties to a device.
