Crashing to desktop with USB-UIRT
Easley
Post by Easley »
Hi, I just download HouseBot today and been playing around with it. I have been using my USB-UIRT with Girder succesfully for a few weeks.
At first everything was going fine as I was learning commands into the Hardware Interface Configuration page for the USB-UIRT. I was learning commands, and testing them successfully. Then I closed HouseBot for awhile, went to dinner, then when I got back it will no longer behave.
What happens is I click Learn, HouseBot opens the "Learn new IR code" dialog, I point and shoot at my USB-UIRT, and when it hits 100% Housebot instantly crashes to the desktop. It also will crashes intermittently when clicking other buttons in the USB-UIRT Configuration screen, like it just crashed when I clicked "Add Remote". It has also crashed when clicking "Click for additional configuration".
Here is my setup:
Windows 2000 Server SP3
HouseBot 1.2
USB_UIRT DLL version 1.0
USB-UIRT Firmware 5.4
Any ideas?
Easley
Post by Easley »
I just noticed there is a dump file created at every crash. Here is a couple of dump entries.
The first one happened when I clicked "Pronto Code...", entered a code, then clicked OK, then clicked save, which it then crashed.
The next one happen at the end of a learn.
====== Begin Dump - Tuesday, May 06, 2003 22:24:48 ======
Server Version = 1.20
Thread Type = Main UI Thread
Thread ID = 334
Fault address: 004BC9C6 01:000BB9C6 C:\Program Files\HouseBot\HouseBotServer.exe
Registers:
EAX:00000000
EBX:07122B90
ECX:071EE370
EDX:00000001
ESI:070B8490
EDI:071EE4C0
CS:EIP:001B:004BC9C6
SS:ESP:0023:0012EE5C EBP:070B8490
DS:0023 ES:0023 FS:0038 GS:0000
Flags:00010206
Call stack:
Address Frame
004BC9C6 070B8490 0001:000BB9C6 C:\Program Files\HouseBot\HouseBotServer.exe
070B6A00 071EB30C 0000:00000000
071E6B70 071E6A40 0001:00005B70 C:\Program Files\HouseBot\Plugins\Interfaces\USB_UIRT.dll
====== End Dump ======
====== Begin Dump - Tuesday, May 06, 2003 22:31:01 ======
Thread ID = 4FC
Registers:
EAX:00000000
EBX:07123228
ECX:071EE370
EDX:00000001
ESI:070B8490
EDI:071EE4C0
SS:ESP:0023:0012EE54 EBP:070B8490
Flags:00010206
Call stack:
Address Frame
Easley
Post by Easley »
Here is some other interesting info:
I went to remote central and got the Discreet On/Off codes for my Denon AVR-5700 (http://www.remotecentral.com/cgi-bin/fi ... ceiver&fc=).
I go USB-UIRT Configuration in Hardware Interfaces.
Click Add
I select a Remote and type a Code Name of "Power On"
I click Pronto Code...
I paste in the Discreet On code
Click OK
Click Close (not Save)
Click Test (and it sends correct IR code via UIRT)
But as soon as I exit Hardware Interfaces the Pronto code disappears.
So I go back in, repaste the Pronto code
Click Save
But the Pronto Code disappeares immediately (i.e. Test wont work)
So it seems like a common thread of all these problems appears to be when HouseBot attempts to commit the changes to disk.?????
I said in my first post that HouseBot was working at first, but I dont think I ever exited the Hardware Interfaces screen. I was just entering codes and testing them. (Although I would have thought I was clicking Save then, cant be sure).
Hope this additional info helps. Sorry for posting so much.
Easley,
No problem on posting too much. I'd rather have too much information, than not enough (the usual case).
I've seen the problem before where if you enter Pronto data manually you can not 'test' it immediately. I think if you save and close the window and THEN test it will work. I'll fix this in the next release of the USB UIRT.
I'm not sure of the cause of your other nasty problem. Can you do the following two things please?
  • 1. Search your system for a file named uuirtdrv.dll. Make sure there is only one in the system and let me know the size and location of the file.
    2. Send me your configuration (HBData.mdb). You can find it in the \HouseBot\Config directory. Send it to [email protected].
Hopefully with the config file I can reproduce the problem.
Also, are you checking the 'code will be send and received' checkbox when learning?
Easley
Post by Easley »
1. uuirtdrv.dll only found in winnt\system32. It is 84kb (86,016).
2. config file sent.
More on the Pronto Code problem
Saving the Pronto code and exiting (without testing) does not help. What happens is I paste the Pronto code, click OK, then click Save, then I exit USB-UIRT configuration, when I come back the Pronto code is gone. If I paste the Pronto code, click OK, then press the Pronto code button again, it is still there. It will even test successfully. It is when I press Save, or exit without saving, that it dissapears. See below for the exact text I am pasting in. Maybe you can duplicate the problem.
More on the learning problem
It seems that only certain IR codes/Remotes cause it to crash to the desktop. If I learn a code from my Lutron remote, it wont crash. I can learn the code, everything works perfectly. But the 4 other remotes I have cause it to crash at 100% of the learn. The remotes are Mitsubishi RPTV, Denon RCVR, and Denon DVD.
Denon AVR-5700 RCVR Discreet On
0000 006d 0010 0020 000a 001e 000a 0046 000a 001e 000a 001e 000a 001e 000a 0046 000a 001e 000a 001e 000a 001e 000a 001e 000a 0046 000a 0046 000a 0046 000a 001e 000a 001e 000a 06d6 000a 001e 000a 0046 000a 001e 000a 001e 000a 001e 000a 001e 000a 0046 000a 0046 000a 0046 000a 0046 000a 001e 000a 001e 000a 001e 000a 0046 000a 0046 000a 0686 000a 001e 000a 0046 000a 001e 000a 001e 000a 001e 000a 0046 000a 001e 000a 001e 000a 001e 000a 001e 000a 0046 000a 0046 000a 0046 000a 001e 000a 001e 000a 06d6
I've got your config file. Unfortunately it didn't help reproduce the problem (the IR code data was not saved).
I'm pretty sure the problem is with the length of the IR code of the Denon IR codes. Your comment about the Lutron remote makes sense if this is true. It's a simple fix and I will send you an update to test shortly.
I'm still looking into the problem with saving the Pronto code data.
This problem has been fixed. Anyone using version 1.00 of the USB-UIRT should upgrade to version 1.01 which is now available from the web site.
