Caller ID not working
kelvin_sudlow
Post by kelvin_sudlow »
HI I have a problem with caller id I can get it going through hyper terminal using
AT&F+VCID=1
the response i get when a call comes in is
RING
DATE=1229
TIME=2310
NMBR=0274414186
RING
But I have no luck with HouseBot, I have noted that in new zealand I am not getting any name info.
I do get the number of rings
Kelvin
Make sure you have the Name included in caller information setting of the Modem/Phone Status interface set to No.
kelvin_sudlow
But I had already tried that but still no caller id
Kelvin
Kelvin,
I figured you had probably tried that, but wanted to make sure.
In looking at the format of the data returned from your modem, it appears as there are no spaces between the '=' signs. The plugin expects NMBR = nnnnnnnn.
Try this plugin and see if it works better. It will accept either spaces or no spaces around the '=' signs.
To install it...
  1. Stop HouseBot.
  2. Unzip the new plugin and copy it to the ...\HouseBot\Plugins\Interfaces directory. You may want to backup the old file before copying over it.
  3. Start HouseBot and let me know if this works for you.
kelvin_sudlow
:( Hi
Still no luck, I have tested it again and all is fine in hyper terminal ie I see the number.
But when i look in the log file there is no call id and none on the device screen. The other info is there no of rings and date
As you have said there are no spaces in callid output
My modem is a Lucent win modem if that helps and I am running XP pro
BY the way I think the software is great
Kelvin
OK. It looks like I'll need some trace data from you to get to the bottom of it. To generate a trace file:
  1. From the HouseBot main menu, select 'Settings/Tracing...'.
  2. Press the 'Advanced' button.
  3. Select the name of the Modem/Phone Status interface in the list (it will be prefixed with an asterisk).
  4. Select the 'File' checkbox and enter a file name in the edit field below (file name only).
  5. Press OK to dismiss all dialogs.
  6. Try and use the interface again. This should generate data in the log file.
  7. Turn the tracing off by returning to the 'Advanced' tracing dialog and removing the check by the 'File' option.
  8. Send the trace file to me at '[email protected]'. The file can be found in the HouseBot\Logs directory.
acheslow
Post by acheslow »
Hi Scott, it's me again - the trouble maker :wink:
I'm having the same problem. Here is my log:
Feb 13 2004	02:16:37PM	Phone	Debug	Character Received [0x41]
Feb 13 2004	02:16:37PM	Phone	Debug	Character Received [0x54]
Feb 13 2004	02:16:37PM	Phone	Debug	Character Received [0x2b]
Feb 13 2004	02:16:37PM	Phone	Debug	Character Received [0x56]
Feb 13 2004	02:16:37PM	Phone	Debug	Character Received [0x43]
Feb 13 2004	02:16:37PM	Phone	Debug	Character Received [0x49]
Feb 13 2004	02:16:38PM	Phone	Debug	Character Received [0x44]
Feb 13 2004	02:16:38PM	Phone	Debug	Character Received [0x3d]
Feb 13 2004	02:16:38PM	Phone	Debug	Character Received [0x31]
Feb 13 2004	02:16:38PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	02:16:38PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	02:16:38PM	Phone	Debug	Character Received [0x4f]
Feb 13 2004	02:16:38PM	Phone	Debug	Character Received [0x4b]
Feb 13 2004	02:16:54PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	02:16:54PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	02:16:54PM	Phone	Debug	Character Received [0x52]
Feb 13 2004	02:16:54PM	Phone	Debug	Character Received [0x49]
Feb 13 2004	02:16:54PM	Phone	Debug	Character Received [0x4e]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0x47]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	02:16:55PM	Phone	Debug	Sending Subscription Notification for list [Ring Information Received]
Feb 13 2004	02:16:55PM	Phone	Audit	[Phone.Time of last Call] has changed to [2/13/2004 2:16:55 pm]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0x44]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0x41]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0x54]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0x45]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0x3d]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0x30]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0x32]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0x31]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0x33]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0x49]
Feb 13 2004	02:16:55PM	Phone	Debug	Character Received [0x4d]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0x3d]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0x31]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0x34]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0x36]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0x4e]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0x4d]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0x42]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0x52]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0x37]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0x30]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0x38]
Feb 13 2004	02:16:56PM	Phone	Debug	Character Received [0x32]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x34]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x4e]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x41]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x4d]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x45]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x3d]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x43]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x48]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x53]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x4c]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x4f]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x57]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x20]
Feb 13 2004	02:16:57PM	Phone	Debug	Character Received [0x26]
Feb 13 2004	02:17:00PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	02:17:00PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	02:17:00PM	Phone	Debug	Character Received [0x52]
Feb 13 2004	02:17:00PM	Phone	Debug	Character Received [0x49]
Feb 13 2004	02:17:00PM	Phone	Debug	Character Received [0x4e]
Feb 13 2004	02:17:01PM	Phone	Debug	Character Received [0x47]
Feb 13 2004	02:17:01PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	02:17:01PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	02:17:01PM	Phone	Debug	Sending Subscription Notification for list [Ring Information Received]
This is an Agere Systems AC'97 Modem on Win2k. I believe it is the same thing as a Lucent WinModem. I tried this fix just in case TAPI was involved somehow but it had no effect. I can still see caller ID name and number in HyperTerminal but not in HouseBot.
Alan
Thanks!
Alan
Alan,
Aww... what do you want for free :wink:
I had resolved this issue with Kevin offline so the thread doesn't have my fix. It seems that some modems report the name and number format (NMBR =) with a space before the = sign and some do not.
Here's the new pluginthat fixed it for Kevin. You will need to copy it over the old one in the \HouseBot\Plugins\Interfaces directory. Let me know how it works for you. If you want to just wait till Monday, version 2.0 has the same fix.
acheslow
Post by acheslow »
Thanks, Scott. If I could wait until Monday I wouldn't be checking the forum every 5 minutes :wink: I see you live not too far from me so I'll have to buy you a beer or a coke sometime...
I can get caller ID working now if I set 'name included in caller information' to 'no', but in fact I do get the name included and would like to use it if possible. There are a number of lines in the log now that say "Warning NMBR= found but no terminator detected"
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0x41]
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0x54]
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0x2b]
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0x56]
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0x43]
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0x49]
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0x44]
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0x3d]
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0x31]
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0x4f]
Feb 13 2004	03:00:53PM	Phone	Debug	Character Received [0x4b]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x52]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x49]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x4e]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x47]
Feb 13 2004	03:01:30PM	Phone	Debug	Sending Subscription Notification for list [Ring Information Received]
Feb 13 2004	03:01:30PM	Phone	Audit	[Phone.Time of last Call] has changed to [2/13/2004 3:01:30 pm]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x44]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x41]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x54]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x45]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x3d]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x30]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x32]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x31]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x33]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x4d]
Feb 13 2004	03:01:30PM	Phone	Debug	Character Received [0x35]
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0x30]
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0x4e]
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0x4d]
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0x42]
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0x52]
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0x3d]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d]
Feb 13 2004	03:01:31PM	Phone	Warning	NMBR= found but no terminator detected
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0x37]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d 37]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d 37 37]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d 37 37 30]
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0x36]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d 37 37 30 36]
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0x34]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d 37 37 30 36 34]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d 37 37 30 36 34 30]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d 37 37 30 36 34 30 36]
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0x38]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d 37 37 30 36 34 30 36 38]
Feb 13 2004	03:01:31PM	Phone	Debug	Character Received [0x32]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d 37 37 30 36 34 30 36 38 32]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d 37 37 30 36 34 30 36 38 32 34]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d 37 37 30 36 34 30 36 38 32 34 0d]
Feb 13 2004	03:01:31PM	Phone	Debug	NMBR= Found.  Buffer = [0d 0a 52 49 4e 47 0d 0a 0d 0a 44 41 54 45 3d 30 32 31 33 0d 0a 0d 0a 54 49 4d 45 3d 31 35 30 30 0d 0a 0d 0a 4e 4d 42 52 3d 37 37 30 36 34 30 36 38 32 34 0d 0a]
Feb 13 2004	03:01:31PM	Phone	Debug	Number Complete.  [7706400000]
Feb 13 2004	03:01:31PM	Phone	Debug	Attempting to set name from name-number lookup table
Feb 13 2004	03:01:31PM	Phone	Debug	No name found in lookup table for number [(770) 640-0000]
Feb 13 2004	03:01:32PM	Phone	Debug	Name and Number Complete.  Name = [], Number = [(770) 640-0000], GetNameInfo = [0]
Feb 13 2004	03:01:32PM	Phone	Debug	Sending Subscription Notification for list [Caller ID Information Received]
Feb 13 2004	03:01:32PM	Phone	Audit	[Phone.Last Call Record] has changed to [Call received from  [(770) 640-0000] at Friday, February 13, 2004 03:01:30 PM]
Feb 13 2004	03:01:32PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	03:01:32PM	Phone	Debug	Attempting to set name from name-number lookup table
Feb 13 2004	03:01:32PM	Phone	Debug	No name found in lookup table for number [(770) 640-0000]
Feb 13 2004	03:01:32PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	03:01:32PM	Phone	Debug	Character Received [0x4e]
Feb 13 2004	03:01:32PM	Phone	Debug	Character Received [0x41]
Feb 13 2004	03:01:32PM	Phone	Debug	Character Received [0x4d]
Feb 13 2004	03:01:32PM	Phone	Debug	Character Received [0x45]
Feb 13 2004	03:01:32PM	Phone	Debug	Character Received [0x3d]
Feb 13 2004	03:01:32PM	Phone	Debug	Character Received [0x43]
Feb 13 2004	03:01:32PM	Phone	Debug	Character Received [0x48]
Feb 13 2004	03:01:32PM	Phone	Debug	Character Received [0x53]
Feb 13 2004	03:01:32PM	Phone	Debug	Character Received [0x4c]
Feb 13 2004	03:01:32PM	Phone	Debug	Character Received [0x4f]
Feb 13 2004	03:01:33PM	Phone	Debug	No name found in lookup table for number [(770) 640-0000]
Feb 13 2004	03:01:33PM	Phone	Debug	Name and Number Complete.  Name = [], Number = [(770) 640-0000], GetNameInfo = [0]
Feb 13 2004	03:01:33PM	Phone	Debug	Character Received [0x57]
Feb 13 2004	03:01:33PM	Phone	Debug	Attempting to set name from name-number lookup table
Feb 13 2004	03:01:33PM	Phone	Debug	Character Received [0x20]
Feb 13 2004	03:01:33PM	Phone	Debug	Character Received [0x41]
Feb 13 2004	03:01:33PM	Phone	Debug	Character Received [0x4c]
Feb 13 2004	03:01:33PM	Phone	Debug	Character Received [0x4e]
Feb 13 2004	03:01:33PM	Phone	Debug	Character Received [0x26]
Feb 13 2004	03:01:33PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	03:01:34PM	Phone	Debug	Name and Number Complete.  Name = [], Number = [(770) 640-0000], GetNameInfo = [0]
Feb 13 2004	03:01:34PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	03:01:34PM	Phone	Debug	Attempting to set name from name-number lookup table
Feb 13 2004	03:01:34PM	Phone	Debug	No name found in lookup table for number [(770) 640-0000]
Feb 13 2004	03:01:35PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	03:01:35PM	Phone	Debug	Attempting to set name from name-number lookup table
Feb 13 2004	03:01:35PM	Phone	Debug	No name found in lookup table for number [(770) 640-0000]
Feb 13 2004	03:01:35PM	Phone	Debug	Name and Number Complete.  Name = [], Number = [(770) 640-0000], GetNameInfo = [0]
Feb 13 2004	03:01:35PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	03:01:35PM	Phone	Debug	Character Received [0x52]
Feb 13 2004	03:01:35PM	Phone	Debug	Character Received [0x49]
Feb 13 2004	03:01:35PM	Phone	Debug	Character Received [0x4e]
Feb 13 2004	03:01:36PM	Phone	Debug	No name found in lookup table for number [(770) 640-0000]
Feb 13 2004	03:01:36PM	Phone	Debug	Name and Number Complete.  Name = [], Number = [(770) 640-0000], GetNameInfo = [0]
Feb 13 2004	03:01:36PM	Phone	Debug	Character Received [0x47]
Feb 13 2004	03:01:36PM	Phone	Debug	Attempting to set name from name-number lookup table
Feb 13 2004	03:01:36PM	Phone	Debug	Character Received [0xd]
Feb 13 2004	03:01:36PM	Phone	Debug	Character Received [0xa]
Feb 13 2004	03:01:36PM	Phone	Debug	Sending Subscription Notification for list [Ring Information Received]
(I've changed the phone number to protect the innocent)
Thanks again!
Alan
Alan,
Yes I added more trace messages to help figure out what was going on.
When I made the fix for the NMBR= parsing (which is working for you now), I failed to do the same for the NAME= parsing. It looks as though that's what you are hung up on now.
My machine is setup for version 2.0, but since you sound really desparate (and mentioned beer), I tried to make the fix to the version 1.6 code base. I hope that it built ok, but I'm really really not setup to test this.
Give this a shot, and let me know how it goes.
acheslow
Post by acheslow »
Scott, just tried out the new dll and I have two words for you - "six pack" :D
I posted another note today about an idea for putting together an Atlanta users group for all of us who are obsessed with home automation, HTPCs, and the like. If there's enough interest perhaps you could participate at one to give an overview of HouseBot and answer any questions about it? Remember, the beer's on me :wink:
Alan,
Great. That wasn't too bad.
I'd certainly be interested in an automation/theater group gathering. It will be interesting to see what kind of response you get to this. I'll wait to respond to your AVS poll (to bring back it into view). That forum is Sooooo active that if someone doesn't respond to you message in a couple of hours, it gets lost in the dust.
