I don't have anything hooked to COM5 yet, so I get this error upon startup of HouseBot. For some reason COM4 doesn't give this error even though there is nothing hooked up to it yet either.
Nov 19 2003,09:56:41AM,Sony DSS,Error,"Unable to open COM Port [5]. Rc = Access is denied."
Nov 19 2003,09:56:41AM,Hardware Module,Error,"Error initializing hardware for module [C:\Program Files\HouseBot\Plugins\Interfaces\GenericSerial.dll]"
So, anyway, if I then try to change a property that is mapped to a serial command on this device, HouseBot exits immediately.
- Jason
Housebot exits unexpectedly in serial error situation
It turns out that I had Girder grabbing COM5 and that apparently is what was causing "access denied". I wasn't actually using that yet, so I was able to fix the problem by changing my Girder plugin to stop using COM5.
Perhaps a low priority future fix to fail gracefully in this situation would be in order...
Jason,
As you have found, the "Access Denied" errors generally mean that another application has opened the COM port first.
Can you look to see if there is a dump file in your \HouseBot\Dump directory? It may have information on the problem where you saw HouseBot disappearing. If there is, please send it to me at [email protected].
