The property value "Temperature" of a temperature device is 'locked' is there a way too unlock this, I want to control the value
Why?, I want to place an temperature device in my car, so when housebot received an temperature then my car is at home.
So I need then to control the value to 0.
Regards,
Temperature device
Re: Temperature device
That can be done by tweaking the HB database.
You can also copy the property using a task to some other NULL Device property which you then use to control whatever your needs are.
Thanks, Richard, I found it, ( so you learn every day)
