At present, the only way I see to do this is to call a script every minute, test the minute of the System Time, and if it's mod 5, launch my program. Am I missing anything in HB that could help me reach my goal here more easily?
Also, in trying to launch my program using CreateObject "Wscript.Shell" etc. I am running into syntax errors that I can't get around, while this same script works from the command line. Is something within HB preventing my launching programs or other scripts from within an HB script? Should I be using a different launch command?
FWIW, I'm trying to run MRTG (perl.exe) every 5 minutes from HB. Here's my script:
dim Cmd
Cmd = "%comspec% /c c:\perl\bin\perl.exe e:\mrtg-2.14.4\bin\mrtg e:\mrtg\ups1400.cfg"
CreateObject("Wscript.Shell").Run(Cmd, 0, True)
