Default Context text
yaccri
Post by yaccri »
I have a panel that It's 'Enter List" has a task that opens a second panel.
The first panel has buttons to open the second panel with context, and the second panel has a remote label to display the current context.
The problem is to display the current context label when first displaying the panels (without pressing any of the panel change).
Is there a way to display the default context label?
Re: Default Context text
You might try the script command "OpenRemotePanelAndSetContext" to first open from the Enter List.
yaccri
Post by yaccri »
Thank you,
That's nice but this script command opens the panel on all software remotes, whereas I need it on the calling remote only.
OK that might be true. I run only only remote and use a video matrix to get the same remote everywhere else in the house. When using a remote device I use VNC.
So never made a difference between calling or all remotes. Too bad
